water system
7
Pearson Pearson 31 Bayfield Wisconsin
I was putting my Pearson 31 in the water this spring and filled the water tanks with the intention of running fresh water through the system. With the water pressure on, the sink in the head ran water just fine, but the galley sink wouldn't work. Has anyone ran into this problem?
NYSail
Jan 6, 2006
3,184
Beneteau 423 Mt. Sinai, NY
Did you check the screen on the fixture to see if it was clogged.
Jun 1, 2005
772
Pearson 303 Robinhood, ME
Only could be a few things... 1 of which has been mentioned. Replace stem... possible clog in water line if antifreeze was used (happened to me once) pink antifreeze crystalized, used a electricians fish tape to break thru.
