W
William Kirch
I have a h-34, 1983. When I went to winterize the water system I ran into a problem and could use some guidance.1. Usung the pressure pump I ran until no water came out of the faucets.2. I put in 5 gallons of the anti-freeze and the ran the pump. The cold water faucets worked well in that the pink anti-freeze came out.3. Then did hot water. At first got a lot of clear water and then no water. I put 2 more gallons of the anti-freeze in the water system-still nothing.The watr pressure system rums but no water or pink stuff comes out of the faucets-either hot or cold.Should I add say 3-4 more gallons of the pink stuff to the water tanks for a total of say 10-11 gallons and then it will work or is their some other procedure.Any help would be appreciated.Thanks in advance.Bill Kirch
