I have a hunter 336 . I failed to winterize the water system and have a leak in the water line. any sugestions on how to find the leak and maybe where to look first?
Yep!!! A freeze busted my galley pump once.If you can drain any remaining water you might be able to pressurize the lines with low pressure air (somewhere around 25psi) using a compressor. You should then be able to hear the leak.
The one spot I would always check is right at the potable water pump -
The other location is at pressurized fittings right after the pump. There is a slight difference between 1/2" PEX tubing and very similar 15 mm PEX tubing and people have mixed and matched those fitting components incorrectly, which can also lead to leakage that isn't apparent at first.
