Water System Fittings
Aug 30, 2015
5
Beneteau 405 Dana point
The fresh water system in my 1986 Beneteau First 405 is fitted with 16mm hoses and fittings which I haven't been able to source anywhere. I'm specifically looking for the compression fittings. They must exist out there somewhere!
Thanks, Richard
Aug 30, 2015
5
Wasn't able to find on Amazon. The fittings are over a 16mm outside diameter hose and are plastic
not brass.
weinie
Sep 6, 2010
1,297
Well, then I guess your username is appropriate ;)
Sorry I wasn't much help.
I have a Jeanneau (eeez like a beneteau) and most of the fittings are whales. I bought some additional whale fittings from amazon to simply winterizing the system.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
look for 5/8 od in that type fitting 16 mm is only 4 thousandths smaller than 5/8 inches
ps........look for pex/watts brand you should get some hits
Aug 30, 2015
5
Watts website shows all their 5/8 fittings under discontinued products, however, found link
to supplyhouse.com and they do stock some 5/8 fittings. I've decided to order a couple of their
fittings and see if I can't make something work. Thanks for the lead.
arf145
Nov 4, 2010
496
Beneteau 331 Deale, MD
I hated the fittings on our Bene's water lines, and all the nasty clamps underneath the sinks, so I just replaced all the water lines with Pex and a variety of push on type fittings.
