Water Supply Cat 30
K
Ken Skoglund
Trying to understand the Water System. Have 2 tanks Starboard side and Bow. Do the tanks feed each other? if not what tank would feed the Hot Water Heater. Probably should follow the Hose connections, but thought someone would know.
H
Hunt
Water tanks come together
On my Cat 30, both tank hoses come together back by the fuel tank and one line continues on from there.
Tom
water system
Ken check out the system plan at this link Catalina 30 owners association
Bob Camarena
Add Selector Valve
Mine was re-plumbed by the previous owner to add a selector valve (mounted to the starboard side of the companionway ladder on the aft berth riser), allowing me to select either tank, but not both. I try to use the bow tank first since it's the largest, saving the starboard tank for a reserve.
Joe DiCianni
What Marina on the Barnegat?
Hunt, What marina do you sail out of? I am located at Mariner's. I have a C30 also. Joe
John Olson
watertank
my water tank coms together under the rear bunk and is made so we can use eather tank and I can pump water from the frount tank to the starbord tank to level off the boat or to move the water weight off the bow for sailing in hight seas John
