Hi Fellow sailors
Interesting problem with fresh water tank, I have a plastic like taste in the water almost like backerlite. have drained the tank several times, have tried the water directly from the tank and taste ok, however when drawn through the plumbing system has quite an odur. I have checked the water filter though it is a stock standard Beneteau filter for major impurities only. Do you have any ideas as to what it can be...?
Thank you.
Thank you.
