T Tom23444 . Jun 5, 2005 5 - - Alameda Oct 2, 2014 #1 Is The Yamnar Qm15 Water Pump Self Priming? If I Disconnect From Raw Water Intake Should It Be Able To Draw Water From A 5 Gal Bucket?
woodster . Sep 15, 2009 6,244 S2 9.2a Fairhope Al Oct 2, 2014 #3 Yes if you have a good impeller if it does not suck water you need to check the impeller
B Blaise . Jan 22, 2008 359 Hunter 37-cutter Bradenton Oct 3, 2014 #5 If you are talking about the raw water pump, it is self priming. If you are talking about the freshwater pump, it is not self priming.
