What is the direction of rotation of the Sherwood water pump on a Universal M18 diesel engine? I'm replacing the impeller on mine, and when I look at at the original impeller before removal, it appears that it rotates counter-clockwise, from the direction the vanes are slanted.That just doesn't look right to me, though. If it's rotating counter-clockwise, the vanes are rotating toward the raw water inlet on the upper left, and away from the outlet on the lower right. I can't see how it could pump water that way. The brass cover is not a lot of help, as it shows the pump rotation in both directions.If it rotates clockwise, why are the vanes all slanted toward the direction of rotation??? I'm cornfused!
