When I run my MD6B engine there is water dripping out of the hole at
the bottom of the shaft that connects the pump to the engine. The rate
is about one drop per second. When I replaced the impeller last year
the problem disappeared but now it is there again (100 hrs).
I noticed that the shaft is a bit worn out and don't see any special
rings or sealings that prevent water leaking out via the shaft, other
than the rubber of the impeller itself. Any ideas how to fix?
Maarten
V2904
Maarten
V2904
