I just replaced my sherwood raw water engine pump with the oberdorfer n202m16. It mated up to the engine block attaching with the same two bolts. I had to shorten one of the barbs on one of thexchanger on the enginecause the in and out ports are closer together on the new pump. I have some pictures if someone wants to how it fits.
But now I need some help as I did not take a picture of the hose routing to the pump. One hose goes from strainer at thru hull fiting to one side of pump and the other hose goes from the heat exchanger on the engine to the other side of the pump. When I disconnected the hoses I didn't notice which hose goes where. Since both pumps have same orientation can someone tell me which port the water intake goes to. when looking at front of pump the two port elbows are pointed downward and to the left (starboard) side of boat in what be the 8'oclock and 7 oclock position.
