I've seen a couple of recent threads about water pumps recycling, and pumps coming on intermittently, but this issue is slightly different.
When using the water on our Hunter 33.5, if we try to use a faucet at low flow, the pump will chatter, that is, turn on and off rapidly. If we turn the water on all the way, the pump just runs as long as water flows. When the pump is chattering, the water flow is steady, not pulsating.
I'd prefer to use a low flow when I can to minimize the tank fills required, but I know that chattering on and off like that is bad for the pump motor.
I have no idea how old the pump is. Could it need replacing or a rebuild? Or could what I'm hearing actually be the bypass working? We're new boat owners so all this is new to me. The pump we have is the Flojet 4405-143
