I have an O'day 222 that was not properly covered and stored outside in freezing weather.
The boat is on a trailer. When I raised the front of the trailer, water came out the discharge hole for the self draining cockpit on the back of the transom. I am assuming there is some kind of hose that connects the 2. Is it correct to assume that that hose is broken and water has gone from the cockpit into the hull. The boat has not been used for several years. How do I fix it? How do I know if there is any additional water in the hull (the front of the trailer is jacked up about 4 feet) and how do I know if there is any damage to the hull? I don't see any soft spots. I would appreciate any advice. Thanks
