On another thread a few days ago I asked about my seemingly low water pressure. I'm getting about .5 gallons/minute and was told it should be more like 2 gallons/minute.This weekend I finished installing an Accugage tank monitor. To calibrate it, I had to fill my water tank. I went topside and unscrewed the water fill plug - and noticed while I was unscrewing it that there was air hissing into the fill hose.That got me wondering about the vent, so I filled the tank ALL the way full and was rewarded with water pouring out the vent fitting in the transom. AHA, I said, obviously the vent hose is NOT blocked!The water pressure was still low, although it improved about 30% when I replaced the in-line filter. I went on to other tasks, but that hissing still bothered me.TWO DAYS later, out of the blue, it hit me: What if the vent hose has a dip in it that allows water to collect????? It seems possible that the water pump might not be powerful enough to suck the water in the vent line back into the tank, and it may not be able to get enough water fast enough to fully pressurize the system.Both the vent and fill fittings are on the side of the tank since it is under the quarterberth. I know that the fill hose has such a loop, but I'm not sure about the vent. It crosses from the port q-berth to the starboard transom, so it's quite possible.I'm so excited about this possibility that I'm even contemplating a trip to the boat (2 hrs rt) just to check it out
It even occured to me that the same situation could happen in a holding tank vent, but I suspect that the massive pump-out system, which can suck a column of water up more than 6 feet, would also suck the water out of an inverted loop in the vent.Cheers,Bobs/v X SAIL R 8
