H23 Cabin
Steve, you didn't mention exactly where the water is in the cabin. Can you explain in more detail? Heeling over 30 degrees isn't enough to allow water over the rails, as any H23 owner can attest to. With such a high freeboard, you have to keep it over 45 degrees for that to happen!More than likely, you have a leak (or leaks- I speak from personal experience here!) somewhere on the deck (hatch mounting hinges, mast step, chainplates, cabin windows, etc.) that is making it's way down to the bilge and spilling out when you heel over, and/or water in the lazarette that spills over the longitudinal seat supports/bulkheads when heeled over hard, makes it's way into the under-the-seat storage space and then into the bilge as has been explained in the previous reply. Don't overlook the anchor locker, sink, and cockpit drain hoses! They do dry out and split over time. With no water pressure inside these hoses, they "weep" rather than spray, so cracks aren't very obvious. The easiest thing I've found is to merely replace them if they're old. Of course, it is also possible that you have a leak at the keel mounting joint, too!Let us know what you find!Jim Maroldos/v: "'Lil Wass Ett III"
