Water marks
Mozz28
Jul 9, 2016
2
Newport 28 MKII Rogers, AR
I recently purchased a Hunter 33.5 that had some water damaged. I was wondering if anyone had an idea how I can stain the water line mark that was left? Is there a product out there that will closely match the wood that wasn't damaged. Below are some pictures Thanks!
Mar 2, 2019
679
Oday 25 Milwaukee
There are a great many variables that determine the color ,hue ,warmth tone ...Might I suggest perhaps staining a piece of cherry or mahogany and applying it horizontally
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I would try just burnishing it with Danish oil and some fine bronze wool or wet/dry paper. You should be able to blend it in.
Likes: BigEasy
Apr 11, 2020
801
MacGregor 26s Scott's Landing, Grapevine TX
Water stains go deep, and I don't know of any process other than deep sanding that will remove them. You might want to consider covering those areas with a thin baseboard. You will have a lot better luck staining that to match, IMO.
Jun 21, 2004
3,225
Beneteau 343 Slidell, LA
Water stains go deep, and I don't know of any process other than deep sanding that will remove them. You might want to consider covering those areas with a thin baseboard..
Only problem with deep sanding is sanding thru the teak veneer into the underlying plywood core. You can sand lightly to bare wood, that will likely still exhibit stains , & attempt to re-stain and blend to surrounding undamaged wood. As you mentioned, overlaying with new veneer or baseboard is another option. Either way, it may not restore to complete satisfaction; but a big improvement, nevertheless.
  • Helpful
801
Exactly
7,747
Alden 50 Sarasota, Florida
Assuming the wood isn’t rotted, it might be a lot easier, faster and less time consuming to cover the piece with new veneer
