water maker: taking the fresh water line to the main water pump?
xavpil
Sep 6, 2022
376
Jeanneau Sun Odyssey 419 Milwaukee
instead to taking the newly made fresh water line to the water tank, my installer recommended to take it to the boat water pump (intake side of course): much shorter route / much easier connection Y or T connector
Thoughts?
Thx
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
Where will the water go if the pump isn’t on? Or is the idea it will just backflow to the tank?
If this is just a shortcut to reach the closest route to the tank, I guess it would work.
Greg
xavpil
Sep 6, 2022
376
Greg
backflow
Oct 26, 2010
2,227
Hunter 40.5 Beaufort, SC
Since the connection you describe would be on the intake side of the water pump, will you have a problem with drawing a vacuum on the water maker output line? The pump relies on "sucking the water" out of the tank that is in service, with another line connected at the pump suction it seems that it might interfere with that suction from the in service tank or worse yet, damage the water maker. I would think you could want to have an isolation valve on the water maker output line just before the water pump. Seems it would be better to have the water maker discharge to a tank that is vented but that is just an "uneducated" guess.
xavpil
Sep 6, 2022
376
I totally agree with you. This is my main concern...
The other issue is the static pressure on the line to the freshwater pump. Typically water tanks draw from the bottom of the tank. The watermaker would have to push water up the intake hose into the tank. That can be a lot of head.
