Water line compression fitting search
Feb 28, 2006
83
Hunter 34 610 Narragansett Bay
Hunter 34 owners,
Purchased new shower faucet and during install found different size fittings. Larger width fitting prevents me from completely tightening nylon nut. I tried local marine consignment store but had 0 luck. Anyone know where I might get the smaller one? I'm in RI if anyone knows of a local source.
Thank you,
Randy Church
s/v Mental Floss
4,450
Catalina 30 MKIII Chicago
Try a plumbing supply house. They're usually much more knowledgeable. There's also a possibility that you have a metric size piece on your boat
Jun 17, 2022
519
Hunter 380 Comox BC
Difficult to tell from the photos how your boat is built. Can you find a label on the line? I presume it's poly-b. Is that the same diameter as the supply line or is there a reducer somewhere?
Most plumbing faucets in North America will have 1/2" IPS / NPS connections.
If poly-b, it could be 12mm or 15mm. You'll need an adapter to go from metric to imperial plumbing fixture.
Likes: kloudie1
Nov 6, 2006
10,195
My H34 has poly butylene lines and fittings. The fittings are imperial and I had no issues finding stuff at Home Depot. It may be that the new fixture is metric? I bought my new sink and head fixtures at Depot .
Hunter 34 Alameda CA
I remember Ace Hardware used to stock the butyl parts as well. They were hanging on the rack at our local store. Is your issue that the tube doesn't insert far enough inside a fitting on the new faucet to seat that nubbin properly? That is where the seal will be. I'm a little confused as to those poly lines. They look like what I had with a captive nut farther up out of the picture. The two are a little bit different? Maybe trim the end slightly with a utility knife.
Likes: kloudie1
