Pressure Test
Hi Jim -Deck leaks can be a real headache, as they often manifest themselves someplace far from the source. If you have trouble sourcing freshwater leaks (and you are certain the water is not coming from the internal fresh water system), try pressure testing the inside of the boat. You'll need a roll of tape, a large shop-vac, cardboard, and a dry day. Start by makinga template of one of the hatch boards out of carboard. Then tape every exterior hatch, port, and locker - fill dorades with rags or anything to seal them. Cut a hole in the cardboard companionway hatch board you made and tape the vacuum hose (hose inserted in the exhaust side of the unit) into it once it's in place. Turn on the vacuum. Now spend some time on deck with a solution of water and soap, spreading the solution on (and in) any areas where you think water might be entering. If you see bubbles, you know you need to rebed or seal that area. The entire process shouldn't take more than 2 to 3 hours, depending on the size of the boat.Best of luck!Trevor
