Anyone ever had to replace a water tank on a 49. Might have a leak under the galley and it looks like a real pain in the **** as all the tanks are sub floor with very limited access. Plus I hear not much sticks to poly tanks and I imagine welding this is not possible due to the access.
Any postive advice is welcome!
The water pump doesn't constantly prime so I'm pretty sure that rules out any pipe/fitting. However, as soon as that tank is filled I get a steady tiny stream in the bilge coming from the rear weap hole, which just builds up over many days and then just sits at the bilge pump switch level.
Going to put some water tracer (green) in the tank to be 100% sure as it has rained constantly for weeks.
Thanks
Michael
Thanks
Michael
