Denise, hunter 23
Think I discovered something today! tada!! The most aft shallow bilge area under the cabin sole. (where the small keel bolts are and the rope tunnel to the cockpit drain goes.) It has too small holes in the side of what appears to be structural "rib" between it and the middle bilge with the full size keel bolts. water seeps from those 2 little holes. We had over an 1" of rain the other nite and the cockpit bilge had a few gallons of water in there. I'm assuming the rope tunnel to the swing keel is leaking from the cockpit bilge to the keel and into the structure. so.. am I correct? Right now the boat is not tilted aft. when I had the boat in the water a few weeks I assumed the keel bolts were leaking. now it's on the dry. and the water is there again. unless... this just occurred to me the hull has water from the deck leaking around the rub rail, stanchions etc? really really love this forum!thanks in advance everyone! Denise
