I am trying to find out how to shutoff the water coming from a grey hose at the clamp where it connects to the cooling water hose. Is there any way to turn off the water access or valve to stop the flow to change the hose. Also the bilge pump went under wwater and did not turn on is it shorted out at the bilge or another place. I have a Pearson 31-2 with a 16 hp yanmar.
thank you
geof
thank you
geof
