E
Ed Childres
I have a water leak at the mast step. During rain storms water runs down the outside of the mast pole on the inside the cabin. I have taken the two ceiling access / inspection plates off during a storm and everything inside is dry. I can see and feel the mast base plate bolts and all of the electrical & rigging penetrations. All of these and the outside of the fiberglass / resin glob that is around the mast pole / keel retraction line conduit are dry. On the outside of the cabin top the only logical spot for a leak is the well with the block for the keel retraction line. This well has lots of factory goop but also retains about half an inch of standing water after a rain. In a rain the water I assume that this well must fill up to a point of covering the line and block.Has this been a problem on other H260's? If yes, what have you done to fix the problem?
