I tracked down a water leak and found it was coming from underneath the fuel tank of my 1982 Catalina 30. Although there is not much room under the fuel tank I was able to see that there are four bolts that go through the hull. (I suppose they are holding the strut for the propeller shaft.) Water was definitely leaking past the bolts. I tried tighting the bolts but no joy. I now have the boat out of the water. Looking at the strut I can't see how any water can be seeping past the strut! It seems sealed to the hull.Anyone had this problem or got any ideas on how to fix it??
