water leak quarter berth
Derek
I have a 27 catalina and have discovered that there a water leak in the starboard 1/4 berth. It appears to run down the bulkhead and puddle under the bunk cushion. I've searched for the leak but can't find the source. Has anyone else had this problem ? Help Thanks Derek.
Rob R.
Sources for Leaks
Derek, check these areas: 1.)Stern rail bases 2.)stanchion bases 3.)Toe rail track for genoa cars 4.)Starboard winch 5.)Companion way hatchboards I had a leak that would not go away until I finally removed and re-sealed the starboard winch. It will leak directly onto the berth cushion. While you are are it, take the winch home, strip and clean it, and repack it with grease. It will sound and function like a brand new one. Best of Luck, and post back with your findings! Rob
Derek
Thanks Rob
The leak was from the Genoa car rail, and I will take the winch home and clean it up. Thanks
L
LaDonna Bubak - Catalina Owners
Be sure to clean the others too
One of the best ways to keep your pockets full of money is to maintain your equipment. I took off my winches to do the first cleaning job but I was also painting my boat at the time. I just repacked them this summer (3 years) and they were almost as clean as the first time - but I live in a mild freshwater environment. Also, if you ever get another mysterious leak over there, check your shore power fitting. Mine was leaking pretty badly and I fixed it but 2 years later it was leaking again. LaDonna
Rob R.
Glad I could help...
And thanks for following up - it's always nice to know how things turn out. Best Regards, Rob
