Water leak on starboard bow1.
NCBrew
Feb 22, 2010
79
Hunter Hunter Legend 35.5 9335 Albemarle Plantation, NC
Preview
I have water infusion on the starboard bow.
It shows up around the wall slats between the 2 places of wood slats near the opening between the 2 compartments on the starboard side?
Where do you think it is coming in?
Patrick
Hunter
7,870
Send pictures to show the general area.
Look for deck hardware in this area.
If nothing shows, off come the wood slats. If you do go this route, continue to take pictures for a record. Next to world peace, boat leaks are the most difficult things imaginable to deal with.
I've been searching for 24 years since the boat was new for a small leak originating somewhere in the area of the anchor locker.
RoyS
Jun 3, 2012
1,742
I just discovered a small leak from the anchor locker. I believe it is coming from a hole I drilled last year for a cable to pass from the v berth into the locker for an electric horn. I suppose water runs along cable and into v berth. Will caulk that soon.
Aug 19, 2021
511
Hunter 280 White House Cove Marina
The worst things about water leaks on the boat, they are a lot like roof leaks. The water always seems to wick away from the hole before it shows up on the inside.
good luck. looking forward to you posting a resolution soon.
