Water Leak in O'Day 27
Jun 14, 2015
30
Oday 30 1110 Lake Grapevine
i have an O'Day 27. I occasionally find water holding in my starboard compartment area under my bench seat. Anyone know where this is coming from and how is it supposed to drain?
Aug 3, 2012
2,542
I would look at rub rail, stanchions, and chain plates. If they leak, the water run downward. Check everything above the spot for dampness.
Sep 16, 2014
172
Oday 272 Ventura
More then likely you need to re-bed some of those items agprice22 mentioned. On the ODAY 272 they are easy to get to. On the 27 little more tricky because you have those cabinets.
