Why so much heel?
Ron, to a certain degree, I think you are letting the tail wag the dog. While any leak is always worrisome, I humbly suggest the problem is less about the leak and more about the excessive heel. The boat will sail better with less heel -- no more than about 15 degrees -- and the cabin not only might be drier, but also less likely to look like a tornado swept through it.It would also put less stress on your rig. You lose a shroud, wet bedding will look like a minor inconvenience. In fact, you lose a shroud, you may find it's your shorts getting wet! Do you sail this hard often? It could be you've pounded the boat into a seam/through-hull failure."Reef early & reef often" is the best advice I've heard for this part of the Hunter line. Food for thought.My 2¢...Good luck & fair winds.---------Kevins/v GrasshopperHunter 23.5Brownsville, VT
