Water leak in Aft Cabin, Hunter 386
Sep 11, 2019
173
Hunter 386 Lake St. Clair
Hey guys,
Looking for some advice. On occasion, we have had water collect behind the headboard ( in the trough) on our Hunter 386. It's coming in behind the wall somewhere. I've sealed about anything I can see on the deck. It has happened when its rained really hard or when I've hosed it off. Wondering if it's coming in around the Gunnel. Is the Gunnel suppose to be caulked on top and bottom? I don't see any. Not sure how it could be the windows, but I'm open to ideas. Is it hard to remove the wall so I can maybe trace where the water is coming in? We pull out at the end of September, so there's not much I can do until then. Thanks in advance,
duck21
Jul 17, 2020
200
Hunter 376 0 Washburn, WI on Lake Superior
I had this same issue on my 376. We re-sealed the frame gaps on the aft cabin ports and that took care of the issue. The water was leaking through the port frames down onto the headliner then making its way over to the headboard.
I am thinking the 386 may have the "newer" standard ports, but I think there is still a frame gap that could become unsealed. We used a little tool to scrape out the dried out sealant and resealed with black 4000UV.
Otherwise, if you have Bimini hardware that may also be just above that area, you may double check bedding.
Doug
-na -NA Anywhere USA
Easy way to find topside leaks is to pressurize the cabin with a leaf blower locating the air bubbling out with the use of a brush and soapy water of course brushing everything on the outside locating air bubbling out. Old yard trick which is faster than hosing.
First close off all ports.
Tape down the forward hatch
Tape off the entire companionway
Cut a small slit in plastic to insert the tube
Tape down plastic to leaf blower tube
Start up leaf blower
Have second person brushing fittings , etc
Mark where air is bubbling out.
as a former dealer I use to find most or all those pesky leaks
Sep 11, 2019
173
Thank you for the responses. Can you tell me if your toerail has caulking on top/bottom?
