As you can see from the video and pictures I have water pushing out from
1) where the sender goes into the top of the tank
2) where the plastic weld is that makes up the disk the sender is attached to
What can I use to seal these two seams? I've tried making sure not to over fill the water tank but then once we heal over we still get a leak so I need to fix this. Thank you!
