Jim Logan
I'm redoing the water intake system for my 2QM-15 - its run for all these years with no filter on the water intake system except the outside bronze slot-type screen over the intake thru-hull. I'm doing this because of age of hoses, etc. not any problems. My question is what sort of filter system (brand, size, etc.) do those of you who have a filter use, and what does the system look like with regard to above waterline loops, siphon breakers, and things like that. Mine has no siphon breakers, no filters, a straight run from through hull to pump - I leave the thru-hull open (I know, I know) all the time and have no problems. It seems to me that a above waterline loop with a siphon breaker would be good, but wouldn't work because of the vacuum necesary for the water pump to pick up water. Any suggestions welcomed.
