Water in the Rudder Post Tube
Sep 22, 2021
294
Hunter 41AC 0 Portland, OR
On our H41DS, I recently had removed the floor panel immediately behind the helm station in order to clean the area below it and to run a new wire from the helm station to the nav station. I noticed when I peered down into the rudder post I could see water, the level of which I surmise is the same as the waterline outside the boat. I suspect that either there is no seal around the rudder post where it exits the hull or if there is one it has failed thus allowing water ingress.
I can see from inside the stern locker that there is a fiberglass "pipe" that runs from the inner hull up to the sub-floor below the helm station, essentially forming a sealed tube through which the rudder post passes. I can understand how this design might eliminate the need for a rudder post seal but I'd like to get some confirmation as to the design of the rudder post structure on this boat. Further, any information on the dimensions and material of the rudder post bearings would be helpful for the future.
I would direct you to the posts by @JamesG161 concerning his boat repair after the Zeta hurricane. He has collected considerable knowledge about the rudder and rudder boat construction.
On his Hunter the rudder has a fiberglass shaft that runs up through a fiberglas tube. The newer boats use a stainless steel rudder shaft that runs up through a fiberglass tube.
Are you seeing the water inside the stainless steel tube? (that would not be good).
Or are you seeing the water out side the stainless steel shaft but inside the tube?
Based on the way the shaft is fixed inside the tube (use of HDPE bearings) you should not be able to look down into the tube.
JamesG161
Feb 14, 2014
7,935
Hunter 430 Waveland, MS
I have a complete understanding of how your rudder shaft, bearing etc function.
Trust me, more than I wanted to know:facepalm:
I also have the Shop drawing, by Hunter, that should included yours.
So if you want to call me today, I can discuss it. [we can start a Private Message]
Jim...
