Sit in your Boat in the Rain
Scott: What I recommend is that you sit in your boat in the rain and keep your eyes open. Rain can come in through many places. I had one window that I removed and resealed many years ago, because it was leaking. I also had a few of the stainless steel fittings to the shrouds, that go through the deck, leak. Also any of the screws to the wood on the cabin top can leak. Silicone sealer is, of course, the solution to the problem, but first you have to find the leak. I even had the fresh water tank to the toilet leak. Again, silicone sealer solved the problem. You might want to try to have someone aim a hose at a specific part of the boat and see if you can detect a leak. I recently found one of my cabin drains leaking and fixed that (but that was another forum article). With patience, you can find the leak. Actually, I have found tracking down a leak many times easier on my boat than on my house. I agree with others who stated that you should not drill any holes between the cabin and the compartments to the bilge. I consider this a matter of saftey. The segregation of the different comparments could greatly help if something went wrong, like a serious leak. Aldo
