Water in the boat.
W
William Kidnew
How do you drain the water out of the inside of the boat? There is about 4 inches of water under the steps, sitting around the hole. As well there is water under the king sized berth. When you lift up the wooden covers you can see the water sitting there. The question is how to drain the water from inside the boat? Thanks, Will
Jenni
May 24, 2007
89
Macgregor 26D Port Hope, ON
Draining water
One way to get water out is the old sponge and bucket method. Your manual bilge pump should also do the trick. But if you are close to shore power those wet/dry shop vacks work great too.
Oct 26, 2004
321
Macgregor 26X Denton Co. TX USA
dry bilge
You should have a manual bilge pump on board at all times. This will remove all but about 1 inch under the galley, and 1 inch uner the aft dinette seat. The remainder is done with ald towels or the sponge and bucket method. Do not sail with that much water in the boat. The wieght shift on heelng could be dangerous to stability and to the battery or other electrics mounted low. After removal, use a hose on the outside to determine where the wate is coming from and fix it. The X bilge should always he dry, except after periods of heavy condensation, in which case, you should open the covers on all hatches and inspection plates to let the boat dry out. To do otherwise is inviting trouble with mildew and wiring corrosion.
Jed Jarrett
Attawood Pump
Attwood makes a small pump powered by 3 d cell batteries it is available at you local lowes or home depot for about 40 bucks... 200 gallons an hour with a 5 hour battery life... it will get most of the water out... then its towels sponges and good old evaporation to do the rest..
70623
Jul 14, 2004
215
Bristol 30 Le Roy, Mi.
Cheap way
You can always take your garden hose and start a siphon. Not fast, but once started it will remove the water while you wax or relax.
May 5, 2006
1,140
Knutson K-35 Yawl Bellingham
I use a shopvac too but it gets real heavy
when it's full. If your vac hose is long enough, you can stick it in the water, start the vac and yank the hose out and place it on or close to the ground to siphon all the water out without filling the vac.
