Water in Rudder - do I drill?
12
Hunter 260 Fremantle
My recently purchased 260's rudder seems to have some water inside - there is a sloshing noise from within. It doesn't sound like a lot of water, and the rudder still floats (yep, had my first sail this weekend – whoo hooo). However, it is of concern given what I have read on this site. The rudder is painted over so I can't see if there is any obvious damage – the old “freezing water expanding problem” is not an issue here in Australia. The yacht has been on its trailer for about 6 months but was kept on the water before that, so any ingress is not recent. My question is this – should I drill some drainage holes to remove the water then epoxy fill these later? If so, is there a sweet spot where I should drill? Or should I just replace in advance of any issue? The build year of the vessel is around 2000.
bob Gorman
Weep holes
Yes you are correct by drilling the bottom ou should create a weep hole for the water to drain and then just epoxy closed.
Apr 29, 2007
12
Swiss Cheese
I took your advice - only needed to drill one hole - about 6 inches deep, diagonally upwards from forward lower corner - about 1/2 cup of water came out and no more sloshing sound. Rudder now enjoying drying out in the winter sun before being refitted.
