Water in rear storage on a 29.5
Twille
Oct 8, 2012
63
Hunter 38 Henderson, nc
So I have water in the scoop storage on my 29.5. I have rebedded the rail feet, the hatch hinges and the ladder bolts. Any other ideas?
Aug 4, 2016
1
Hunter 29.5 Vancouver
I've got the same issue on my new to me 29.5. Had a full marine survey done and this was clearly missed so I'm hoping others have suggestions. There's a scupper at the bottom of the swim platform but it seems to do more harm than good given it's almost always below the waterline when sailing. From there the water seems to also flow into compartments on the starboard side aft; specifically under the aft cabin where it doesn't have drainage into the bilge. The propane locker remains bone dry and she'll stay dry as long as she's docked... it seems like a silly place to put a scupper; what do others do; plug it while under motion? The fact the water gets all the way back to under the aft cabin and can't drain into the bilge is my biggest concern at the moment.
Apr 3, 2008
12
Hunter 336 Montreal, Canada
Had the same issuein my 336. It was the wet exhaust tubing that was cracked. You can easly test this buy pumping out water after you use the engine and go sailing. If you don't have any water after few hours, its definitly your hose. Changed mine in 30 minutes and it was about 250$. Good luck
Twille
Oct 8, 2012
63
I am still working on this. I put a 3rd clamp on the exhaust and it does not seem to leak while sitting at the dock running. While under way the rear rub rail has water over it. I am wondering if it's the seam under the rub rail. It collects no water while at anchor or docked only while moving. The rub rail is above the water while at rest.
