It's a big deal
Dave, water in the bildge is a big deal. I have spent the last two years bringing my 25 O'day back to sailing life. It's previuos owner had the same outlook on water in the bilge, that was until the chain plates started pulling out of the bulkheads.Thats were I would start, check the chainplates, you should pull the hull liner back at the bulkhead for a good look. Check the anchor locker drain hose in the V-berth, check all through hull fittings and hoses, if they are old REPLACE THEM! Another overlooked spot is the rubrail, the screws that hold it on go right through the hull and water will leak in. The hull liner will be stained were it is leaking.I have a no water "in the bilge" policy,I check my bilge every time I first get on the boat and so far she is dry as a bone!I found my leaks one sunny afternoon with the boat still on the trailer. I got the lawn sprinkler out, set it on the tabernackle, grabbed a few cold ones and turned on the water.Good luckDoug
