water in battery area
Jun 12, 2021
297
Hunter 240 Aqualand Marina, Lake Lanier
The bilge area under the rear if the cockpit has about three inches of water. there are no limber holes to allow it to flow forward to the area under the aft bunk where the bilge pump is. Is this by design?
Jun 12, 2021
297
Yes, it is a H240. The water will eventually flow through the hole in the bulkhead for the wiring and discharge line to the bilge pump. I plan to drill some limber holes unless there is a reason not to.
-na -NA Anywhere USA
There is more to this issue that you may be unaware of to include leaks and clearing the weep hole. Send a or a message through the forum email
