Hi all, took the weekend to get familar with the boat and its functions (as many as I could manyways) also cleaned up the bilges, they were pretty dirty. I cleaned the whole main bilge but I noticed that the battery and engine didnt drain into the main so I could pump it out. the battery compartment was full all the way to the top with nowhere to go so I used a cup and got rid of most, also the engine right behind it had water. I dont know if it was fresh or salt...Is there a seperate pump for the engine and the little battery compartment on the 361 ? (battery is under the last step walking downRegardsGaute
