Water Help
7
- - Norfolk
Can anyone give me some advice on how and with what to replace the manual head faucet with an electric one? The only use of water on the boat is for the head, and it gets used a lot. The manual faucet leaks and has popped out of the fixture. please help!!
Dec 2, 2003
110
- - Rochester NY
Do you mean having water available by
just turning on the faucet like at home? I don't know of any electric faucet that does this but if you're referring to a pressure water system, this requires the addition of an electric water pump plumbed into your waterlines as well as the addition of some wiring, a fuse and an on/off switch to your electrical panel. And that's the extent of my knowledge on this subject. :) Good luck!
May 23, 2004
117
Catalina 30 Stockton, CA
Jabsco
Jabsco makes an inexpensive electric pump and faucet that may be what you're lookng for. I've attached a link to it in the West Marine Catalog.
