water heater
stevew
Oct 17, 2006
5
- - deale,md
I have traced a slow leak back to my Force 10 water heater. Before I start this project does anyone have past experience to share. My boat is a 2004, 326.
Ross
Jun 15, 2004
14,693
Steve, I have no experience with Force 10
water heaters but with water heaters in general most of the leaks are in the connections, it is rare for a leak to occur in the tank in a unit as new as yours.
Jun 4, 2004
125
Hunter 333 Elk Rapids, MI
check the safety valve
The safety overflow valves are notorious for leaking. All it takes is a little piece of grit in there to make it leak.
Jun 4, 2004
19
Catalina - Myrtle Beach
I Agree With Steve
I had a leak from the water heater to turned out to be from the pressure relief valve on my 2000 C-320.
Shippy
Jun 1, 2004
272
Hunter 356 Harve de Grace
Connections
Mine also leaked where the cold water source entered the unit. The PO (I'm guessing) installed teh wrong type of cold water fitting. Simply switching the fittings fixed my problem.
May 18, 2004
385
Catalina 320 perry lake
When I purchased my boat
the PO had not drained the water heater the previous winter and the tank (which you can't see because it is in a metal box stuffed with insulation)had a split in it like someone had hit it with an ax. Replacing the unit was not too expensive (in the boat world) and was pretty easy. It all depends on your access. Since I couldn't see the leak but kept finding water in the bilge it took a while to figure it out.
Jul 12, 2004
285
Catalina 320 chestertown
Leaking Water Heater
My hot water heater leaked water just from a combination of poor fitted hose clamp and worn out two inch piece of hose. Replaced both and the the leak stopped. I had to use the black hose with the green strip. I agree that a water heater leak you should suspect the connections first.
Jul 1, 2007
169
hunter 29.5 Nanaimo BC
leak
I was sure that I had a leak in my water heater, but it turned out to be my forward hatch.There was very little sealant under the frame.I think the installer had to buy his own. Water was coming in and running forward above the headliner to the bow, running down under the anchor locker and into the bottom of the boat showing up as a puddle around my heater. Be sure before you go to a lot of work.
Jun 4, 2004
629
Sailboat - 48N x 89W
Use steel barbs
Plastic pipe & hose barbs should not be connected directly to a hot water tank. Use steel hose barb fittings to connect hoses.
