Water Heater
Tim Radigan
I have to replace my water heater - any suggestions on a replacement part.
Dec 2, 1999
15,184
use the same make
Tim: I recommend that you use the same make and model if possible. I think that they are comparable in performance and the hassel of changing fitting etc. is probably not worth the trouble. And that's my OPINION!
P
Peggie Hall/Head Mistress
Why do you have to replace it?
Unless the tank itself has rusted out, you don't need a whole new water heater...just a replacement for the failed part.
Seamus Carney
Are you sure
Mine quit two years ago. Found a chafed wire inside the front panel, after replacing the wirer it's worked fine. It also could be the element.
