Water Heater
Rod Lopez
I am looking for information on a compact water heater that can be mounted on a bulkhead. I have very limited space for conventional units. It has to be able to work AC/Eng
Rob Homan
Water heater...AC/engine fed
You can go to the BoatUS store down that way and they will have what you need on the shelf. There are several different models of water heaters. Round ones and square ones, 6 to 20 gallons. On our boat the water heater is located up and behind the engine on a platform affixed to the bulkhead. Ours is a 6 gallon unit. We liveaboard and it gives us plenty of hot water.
L
LaDonna Bubak - CatalinaOwners.com
Paloma - instant hot water
My folks used a Paloma on their boat
Jul 1, 1998
3,062
Check Out Espar
Expar makes a very compact hot water heater. It isn't a bulkhead mounted type but is better suited for a mechanical space or lazarette. Dimensions of the D5 with up to 17,000 BTU output are 3.5W x 6.3H x 10L. This is really compact. It runs on diesel and most importantly, the exhaust air is vented overboard. Their web site is: http://www.espar.com/htm/Specs/water/wterheat.htm
