Water heater
Sep 15, 2019
31
Yamaha 33a San Juan Islands
Anybody have ideas on location of a propane hot water heater on a yami 33
Trying to avoid going with the usual 6 gallon 110 unit
Thanks all
Dan
Shogun
Yami 33
San Juan Islands
Dan..
Why would you elect to carry two types of energy consuming systems onboard (Propane and Diesel) to heat water?
I know that while I sail, that frequently the bearing I desire to cruise is dead into the winds of the PacificNW. That is if the wind gods are favorable. In such conditions I resort to the use of my iron genny. The diesel heats the engine water and when shared through my water heater it heats my 6 gal water tank. A two-fur one. With good insulation on the tank, the water stays hot for about 24-36 hours. If I am sitting at anchor and I need water hot water for cooking, it is a quick boil on the stove. This minimizes my propane consumption to cooking.
If in a marina I can utilize the electrical heating coils in the tank rather than burning propane.
My experience over the past 7 years has been positive.
capta
Jun 4, 2009
4,947
When I had a trimaran I had a propane fridge/freezer partially mounted so that any leaking propane would go directly overboard. That would be pretty difficult to do with a water heater, and I wouldn't be comfortable with it being mounted where I couldn't smell a leak immediately, and no way to vent the gas overboard.
Yes I know, stoves are propane and mounted below, but they are in the cabin one lives in, so a leak should be relatively quickly identified. Stoves also have a remote solenoid shutoff, which would be a major inconvenience IMO for a hot water system. I have investigated the on demand systems, but never used or installed one on a boat.
Nov 21, 2012
747
Yamaha 33 Port Ludlow, WA
Be advised that unless your propane water heater is marine specific and/or USCG approved, your insurance company will balk. Propane devices with a pilot light are not allowed on vessels with one exception:
ABYC A-26.5.9 Pilot lights and other automatic ignition devices shall be permitted only in appliances with room-sealed combustion systems.
I'm not aware of an approved propane water heater, but I haven't looked in a while. If you go with a diesel heater, you can add a calorifier to heat water: https://www.bobilvans.co.uk/product-page/calorifier-upgrade-kit
