Don
I replaced my leaking Seaward 6 gallon water heater with a force 10 (now KUUMA) water heater. The old one allowed the water to get very hot from the engine heat exchanger and most times I would still have hot /warm water the following morning.The new water heater does not get nearly as hot and definitely does not stay hot for as long.The factory people tell me I need a check valve on the cold water intake as there will be a heat loss in the line backing up to the pump. This does not seem reasonable - any other thoughts.Thanks Don
