Attached are some photos of water damage on the bulkhead of my C36 MK II. Originally I had thought that the water was entering from the chainplate attached to the bulkhead. I reset all the chainplates, but the water damage continued. It's possible that I didn't do it right, but as you can see from the photo, some of the water stains are above where the chainplate passes through the deck. NOTE: The bulkhead is on the port side of the boat, alongside the mast and runs from right next to the mast all the way to the hull - thus passing under the (higher) cabin top and the (lower) deck, which is of course where the chainplate passes through. In other words, if it were only leaking from the chainplate, the water would have to run uphill on the bulkhead. I know water does funny things, but I don't think this is likely.
So I'm trying to figure out where the water is entering. The mast is keel stepped. Is it possible that it's entering around the mast? If so, would I have to pull the mast to fix this? Another possibility is the tutning blocks just behind and alongside the mast (see photo).
One final point: Originally I was going to pull and replace the bulkhead, but now I'm thinking of just routing out the dry rot, which is about a half inch deep and confined to the bottom and putting a piece of teak like a baseboard to cover it. Comments?
