Tim
I have an 8 year old Adler Barbour Super Cold machine. I'm moving onto a mooring this summer rather than a slip and so amp draw is a bigger issue. For the existing setup, I'm running on about a 50% on/off cycle in typical New England summer usage. What's likely to offer to biggest improvement?-adding water cooling (Expensive if I use your kit. Why does a tiny pump cost $270?)-adding insulation (not easy unless its inside the box)-adding better ventilation to the area where the compressor lives (its not terribly well ventilated now and gets quite warm in the summer. But a fan costs amps...)
