water cold/hot
C
cyrilmartin
I am owner of a 36' nonsuch and I cannot regulate the shower temperature. The bathroom faucet can be adjusted to the correct temperature. But when I connect the shower hose to the faucet I cannot set the temperature. I get either all hot or all cold. It seems like the pressure from one pump cuts out the other pump. I am badly in need of someones advice.
Thank you
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
More than one pump?
You have a pump for hot water and a separate pump for the cold water?
Do you have a picture of the bathroom faucet/shower system? It may help in determining the problem.
It may not hurt to post this in the Head Mistress forum.
Manny
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Can't say I ever heard
of seperate hot and cold water pumps. Sounds like one pump simply overpowering the other one when the flow is restricted, as it would be in a shower head.
