The REAL reason for water ballast!
BTW- Doug is right; the 'Venture' boats did not have water ballast. In fact they had no ballast at all except the keel, and this is why Macgregor thought to include foam flotation. Some people could correct me but it's probably as easy to tip over a 22-ft Venture than it is any other dinghy.The REAL reason for the recent push for water ballast by Hunter and Macgregor and a few others has very little to do with efficiency at all, but if you believe it does then it proves the marketing people's point and you might as well go buy one. Some race boats started using water ballast about 15 years ago, not for the reasons it's on trailerable boats but because it allowed them to MOVE ballast from the low side to the high side. Sailboats are fastest and safest when they are sailed closest to FLAT (and try moving several 80-lb lead pigs to the high side inside a racing sailboat whilst under way sometime). The deciding factor in racing was that any water ballast INSIDE the hull was weight unnecessarily high which should be added to the keel, by increasing depth (which does not matter in an ocean racer) or adding a bulb on the bottom or something. I don't know how popular water ballast is with high-perf ocean racers now. I wouldn't want it. Some guys started going to spent uranium (I kid you not) because it is heavier per cubic foot than lead and so takes up less space for the same weight in the very skinny bottom end of a knifeblade keel.And therein is the REAL reason. The last time I bought lead at Cherubini Boat it was 31 cents per lb at 60,000 lbs per order. Lead is the boatbuilder's gold standard. Now imagine if you didn't have to spend that at all-- just build a boat, tell the buyer to flood it with (FREE) seawater, and think of what you would save. And then charge him EXTRA because it's like an added special feature you're giving him, right?And yes, you guessed it-- since this is a cost-cutting strategy above all, it is a performance, safety, and quality COMPROMISE. And you thought they did it to do you a favour!JC 2Cherubini Art
