"lite air speed"
Water ballast systems will heel to optimum angle with minimal wind force. This is good news because the wetted surface is reduced and more speed is the result. Let's say then, that if you can keep your ballast in place (tell your passengers to walk on eggs), you'll get up the speed and generate some apparent wind. Water Ballast really shines in lite air. The high center of gravity does mean that heavy weather isn't the optimum condition for the boat, but my body agrees with that. Another characteristic of the 26/260 that should be noted is the high freeboard. The wind really plays a dramatic effect on it's leeway, especially while navagating in close channels. I use power to assure a true course.A spinnacker can really over power the boat but it also can enhance the performance when it used properly. Every boat has it's unique characteristics. It's like learning how to dance with somebody. When you know how to do it, it really looks and feels good.I commend you on your investigation of these boats. It will allow you to have an expectation which is in tune with the design and performance of your vessel. Less surprises, more pleasure and most importantly no regrete is the result.Have fun on the H2O,Larry Barnes"CNTRL SEA"
