SurfTom
Thanks to all who helped with the Rudder inquiry.Next question: I was a little surprised when I filled the water ballast (thru the hull bottom) while launching. It seemed as though it took 15 to 30 seconds...not very long at all. When I look into the top side fill hole the level is within maybe 4 inches of the top. The boat feels very tender which may have been due to tiller being loose and trailing in the mid-way position. I've opened the valve while under way thinking that maybe that would push more water into the hull. Seems to be at the same level. Does anyone know how long it takes to fill? AND,,,that last 4 inches depending on the length of the bladder could mean many gallons of water. Is it filled?
